Threads: 12
Not that difficult if you have the tools and time. Paragon is more than willing to help you through the conversion if you have any questions. If I remember correctly you need a large drill bit to drill the hole in the bottom of the strut tube. At least it was not a size that I had on hand and had to purchase.
I wish I would have purchased the H&R springs at the time of conversion because now I am waiting on the springs and will have to tear it apart again. Last time I talked to paragon the springs are on back order. I expect to get them in the next couple of weeks.
Remember......measure twice, cut once.
Good Luck!!
Bart
'92 968 Arrest me red Coupe
'71 G-Production 510 #61
Threads: 12
[quote name='flash' date='Mar 14 2005, 06:28 PM']bummer - a second alignment
[right][post="1870"]<{POST_SNAPBACK}>[/post][/right][/quote]
Exactly!!
Bart
Threads: 51
Let me just add that I have also done the conversion successfully. Don't forget that NAPA stores and others will let you check out strut compressors. It took me a couple of days for the whole job, including painting the struts. Don't forget to replace the rubber bits while you're in there (dust shield and bumpers). I replaced my control arms at the same time.
Oh - there's a place in the Paragon instructions where I think they mention getting a long bolt to draw the shock into the strut body - my advice is to definitely do that - it makes the job so much easier.
Threads: 12
Quote:Oh - there's a place in the Paragon instructions where I think they mention getting a long bolt to draw the shock into the strut body - my advice is to definitely do that - it makes the job so much easier.
[right][post="1934"]<{POST_SNAPBACK}>[/post][/right]
I missed that part in the instructions and was trying to figure out the best way to get the strut insert sucked down in the strut tube....so I called paragon. After talking with them I simply slammed, for a lack of a better term, the insert into the tube and bolted it down.
Good Luck!
Bart
(This post was last modified: 03-18-2005, 07:44 AM by
Bart.)
Threads: 51
[quote name='Bart' date='Mar 17 2005, 09:50 PM']I missed that part in the instructions and was trying to figure out the best way to get the strut insert sucked down in the strut tube....so I called paragon. After talking with them I simply slammed, for a lack of a better term, the insert into the tube and bolted it down.
Good Luck!
[right][post="2008"]<{POST_SNAPBACK}>[/post][/right][/quote]
[quote name='Greimann' date='Mar 17 2005, 11:18 PM']slam the assembly down
[right][post="2011"]<{POST_SNAPBACK}>[/post][/right][/quote]
Jeez guys... take it easy! I didn't want to damage either my precious workbench nor my precious new yellow strut. The "slam" technique reminds me of tee shirts printed by my favorite contractor:
"If it don't fit... force it"
Other titles:
"Good enough for who it's for"
"It's what I am... it's what I do"
"Can't see it from my place"
"Measure once, cut twice"
"It's the contingency, stupid!"
"It took a little longer than I thought"
"I'd rather be lucky than good"
<img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
Threads: 51
uh... on re-reading my post I'm not sure it's clear that I'm NOT criticising anyone's technique other than self-deprecatingly admitting to being over-cautious sometimes. er... the tee-shirts *are* quite funny! have a great weekend everyone.
