Airbox Modification Article & DIY
With all the hype out there about cone filters and such, controlled testing was done to see what worked best and why. When all was said and done, the factory airbox, with a modification and a K&N filter element, worked much better than any cone filter, with more surface area, colder intake temps, and produced an astounding 10.8 hp on the dyno.
Here is the Airbox Modification Article as it appeared in 9 Magazine:
I have completed this modification with K&N filter. I used 4 2" by 1" subwoofer ports found on eBay for under 2 bucks.
Now my questions, are:
Do I leave the snorkel piece un-installed? As shown in DIY photo?
I do not have engine trip piece surrounding air box, it is best to have a shroud or the trim piece for cooler air, or is that trivial?
I just assume keep snorkel in place as designed , and let additional holes enhance airflow.
Thanks again everyone, awesome site.
FQ
remove the snorkel and the gasket around it (the snorkel picks up hot air from down by the oil cooler which is 250 degrees)
leave the front trim piece in place to help isolate the intake from engine bay heat
Thank you Flash, I did not expect you to respond so quickly. I will do as you have advised.
GO ON Vacation with your wife and relax. Have a great trip!!
FQ
lol - i'm still around for a couple of weeks yet - miles to go before i sleep
Last Post by Kunz
05-06-2015, 09:55 AM
Last Post by firefish
01-10-2011, 01:24 PM
Last Post by Renalicious
02-19-2007, 02:52 AM
Last Post by schwarz968
08-05-2005, 11:52 PM
