[quote name='Kim' post='29379' date='Dec 24 2006, 03:44 PM']Could somebody send me a picture to show me if the air flow sensor is mounted with the plug up or down? Mine is up and it seems to be slightly hitting the hood and causing a chafe on the underside and a dent on the top. There isn't any room to adjust. Note that wires are brittle and probably won't take a lot of wiggling.[/quote]
Take a look at the bottom right hand part of this photo... I think it shows the connector to the MAF mounted on the bottom, and is to the best of my knowledge, the way Porsche and God intended it to be ;>))
I can't check it as the car is in winter storage. Best of luck!
