Threads: 59
For the last couple of weeks I have been dealing with some drivability issues. The car kept surging when I was off or partially off the gas pedal. Initially I thought it was a vacuum leak. However a vacuum check confirmed there to be no leaks, but the problem persisted and got worse and the fuel consumption nosedived.
Error codes indicated that the car was running to rich. My PM has determined that the MAF sensor has failed. Cleaning it had no impact on the problem. He disconnected the MAF and the cars runs significantly better than before. It appears as if there are no MAF sensors to be had in the US at the moment and only a handful in Germany according to Porsche and a new one from Germany will cost north of $700.00. My PM will take a harder look at procuring one next week, but I am wondering about the wisdom of using one from a salvaged car, assuming there are any to be found in a salvage yard. Your thoughts are appreciated.
Chris Vais
2008 Audi A5 Brilliant Black
Threads: 3
The unit is pretty much the same as a bunch of common Bosch equipped Saabs, Volvos, Audis, etc except for the egg crate flow straighteners in place of the typical screen. I have run with a Volvo MAF with no ill effects. The Audi RS2 (Porsche tuned) uses the same MAF also but these are also hard to find.
There is data out there showing the RS2 MAF has the same output curve as the Audi 200 MAF but a little less flow due to the screen on the latter.
http://www.s2central.net/ds_G70.html
If you are in a hurry to get back on the road try an Audi 200, Volvo 960 V6 MAF or the similar unit from the old Saab 9000 and run it while you get your 968 MAF rebuilt by Injection Labs here in beautiful Boulder Colorado. Or swap the sensors between the common housing and the uncommon 968 / RS2 housing and go drive.
Cheers,
-Joel.
Joel Frahm
1987 928S4 Diamondblau/Blue
Threads: 3
Joel Frahm
Threads: 77
(This post was last modified: 08-20-2011, 02:59 PM by
banditsc.)
Threads: 59
The <acronym title='mass air flow'>MAF</acronym> was cleaned, actually wasn't all that dirty. The problem is that there is no signal from the <acronym title='mass air flow'>MAF</acronym> to engine management computer whci suggests that it has failed in some manner.
Chris Vais
Threads: 59
Replacement <acronym title='mass air flow'>MAF</acronym> installed today and the call really runs much better. The replacement was a used one from RS Barn. I've been driving the car without a functioning <acronym title='mass air flow'>MAF</acronym> for about a week and a half. What a pig, it consumed a vast amount of fuel, no grunt off the line and a huge flat spot in the power curve. But it is back in good form.
Chris Vais
Threads: 45
The same one mentioned above for the Volvo V6 is the same as a 355 the only difference is the mesh grill instead of the egg crate in the 968 one.
You are quite safe using the cheap one off eBay for $50
Threads: 45
We had the cheap one on a dyno today and ran them both one after the other
The cheap one had a better curve than the original figure that one out
50 dollars better that close to 1000 dollars and it does not have a Porsche or Bosch label on it
Threads: 45
(This post was last modified: 09-06-2015, 04:35 AM by
Waylander.)
Threads: 167
<sub>
I like Wildcat's solution. Can I install the $2,000 Ferrari MAF to replace the $1,000 Porsche part. Hidden bling
</sub>
(This post was last modified: 09-06-2015, 09:17 AM by
94SilverCab.)
