Threads: 45
The front one (blue AMP plug) is the coolant temp sensor for the ECU, the one behind that is the feed for the dash gauge (2 spades)
There is a third sensor up the top by the fuel rail level with the variocam solenoid, this is the oil temp sensor for the ECU, for switching the vario and the emissions vapour burn valve
(This post was last modified: 12-20-2020, 06:45 PM by
Waylander.)
Threads: 45
Cant really call the rad fan switch a sensor, its just a temperature controlled switch
