Threads: 104
Thanks guys! Just curious, my replacement used compressor is from a later 968 so it says R134A on it. How does it compare to my original 92 compressor? The same?
92 968 cab, 1 of 1 Mint green cab, full leather black intr, PCNA promo car, 9th cab for NA market, 6 spd, 968 coupe and cab registry keeper. PCA 968 register advocate.
Threads: 77
From what I have seen, it's the same. Just different seals in it.
Threads: 104
What's involved with the refrigerant charge? Easy? (R134a)
Threads: 77
It's a shop job unless you got all the tools. Mainly a good vacuum pump for when you get everything back together and ready to charge it.
Threads: 104
Thanks Bandit, are the two O-rings the same? 944 126 935 01 They look different on the part but Pet says only 1?
Threads: 77
The top of the compressor where the hoses attach actually take four of the same o-ring. Your actually better off picking up one of those 100+ metric A/C o-ring kits for like $20 or something. You will have more then enough of the various size rings you need, I done a few cars with them. There are a number o-rings in the system that need to be replaced.
Threads: 104
Bandit,
Thanks again, i was only planning on doing the 4 since I'm just replacing the compressor. I'm assuming the others were done when the A/C was converted.
Jeff
Threads: 77
You would be suprised.. Some shops concept of conversion is screwing on the adapters to the charge ports and calling it done. If there are any black o-rings in the system, it wasn't converted. The hardest ones are at the expansion valve, which also should be changed for R134a conversion. I think in the 968 you need to get the dash out to get to them.
Threads: 104
Bandit,
Is there a way to determine where a leak is happening?
Jeff
Threads: 77
If the refrigerant has dye in it, you can use a black light to search for the leak. A large leak would leave you with green stuff leaking from the area. Another method is with a sniffer, but you would need a shop for that.
Threads: 104
And if it is the expansion valve under the dash that is leaking I can imagine that would be a challenge to identify and fix, right? Thanks!!!
Threads: 77
Ya, it is a pain to get at. You can either roll the dice and leave it and hope the o-rings are good or replace it. The expansion valve opens and closes at a specific temp, normally they are different for r12 and r134a based on the temp ranges of the different refrigerants.
Either way, when you go to have it charged and they pull a vac on it, they will be able to see if the system is holding or not.
(This post was last modified: 10-19-2010, 02:55 PM by
banditsc.)
Threads: 104
"Either way, when you go to have it charged and they pull a vac on it, they will be able to see if the system is holding or not.
Hmmm, so they should know? Even small leaks? I lost my refigerant after 2 days. The shop that did the upgrade said it was probably the compressor but shouldn't they have known that?
Thanks for your help.
Threads: 77
They should have put a vac on it and checked it for leakdown. They may have seen leakdown and guessed at where the leak was. They could have done some sniffing or black light work to actually track down the leak.
