Threads: 77
From what I have seen they are all the same compressor. The only difference with the newer ones was the different seals and oil that was used for R134A. All the compressors sold today should be up to the R134A standard.
Threads: 77
Your car should of originally had R134a, so just make sure you get out all the old oil from that older compressor. It has a different type of oil in it that doesn't mix well with the R134a oil. You will also of course need to replace the receiver/dryer while your in there.
Threads: 77
The receiver/drier is the aluminum barrel shaped piece behind the drivers headlight. The ac receiver drier is used to take all of the water out of the ac system, and to take out any contaminants that may plug the ac system. The ac receiver drier should be changed every time you remove any ac component that exposes the sealed ac system to the atmosphere.
