Will these wheels fit?
Front: 18x8 +59mm with 245/50 tires
Rear: 18x9 +53mm with 275/45 tires
Curious....
Plugged the numbers into the wheel calculator, and while the calculator tells you of the changes the new wheels create, it doesn't really indicate if the new wheels fit or not.
BTW- those numbers are from new 18" Panamera take-offs.
wheels will - tires probably won't - WAY too tall - OEM O.D. is 25" - those are both over 27"
tires will likely hit lot of things
speedo will be way off
final drive ratio will change
likely very heavy
abs might not work
Thanks.
Last Post by 94SilverCab
01-12-2021, 10:23 AM
Last Post by MCL968
03-01-2017, 11:35 PM
Last Post by Carl968
10-16-2016, 06:40 PM
Last Post by JWahlsten
06-01-2015, 10:35 AM
