Threads: 224
As I wait another day for my 68 to arrive <img src="/forum/images/smilies/968/mad.gif" class="smilie" alt="" /> , I was wondering. What was the first thing that you changed on your 968?
Threads: 25
The water pump <img src="/forum/images/smilies/968/mad.gif" class="smilie" alt="" />
Rick
Threads: 27
The tires! The previous owner decided to put his 911 tires on the 968. Not a good match. The car felt like it was moving on its own.
I sort of look at a car like buying a house - you have to live with it to find the problems. However, after a couple of tweaks here and there all is good.
Threads: 81
[quote name='Renalicious' date='Jul 11 2006, 10:14 PM']Water pump, 4 rollers, timing belt, balance shaft belt, front seals, spark plugs, oil and filter, break fluid, and coolant <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
[right][post="23948"]<{POST_SNAPBACK}>[/post][/right][/quote]
That plus a radiator and some gearbox fluid.
Threads: 10
Three weeds ago, when I arrived home with my 'new' car after 2,300 miles, I installed the DME relay, then did the airbox mod., installed the RS Barn chip, K&N filter, strut brace, new brake pads and off the to track the next weekend for a two day DE. Is there such a thing as 968 overload? My wife thinks so <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" /> I still have a list of changes to make.
Cheers,
Stephen G.
Moscow, Idaho
'93 Guards Red coupe, 6-speed, LSD, 17's, chip, strut bar, M030 sways, airbox mod,
Threads: 10
The first mods I made were new 968 floor mats, KLA strut tower brace, and a windscreen to keep that autumn draft off my neck when the tops down.
After that the flood gates opened and it seems that every month I'm adding some sort of mod.
Luckily, I have only had to make a few repairs and they were inexpensive but I'm going through a preventive maintenance phase a the moment.
The most expensive mod I've made was replacing the worn and tattered convertible top.
I highly recommend starting small and work your way in to it. The 968Engineering air box bolts are very handy. Also Harvey's door sills add a nice touch.
Good Luck
________________________
[color="#3366FF"]1995 Porsche 968 Cabriolet
1997 Mercedes Benz E320
2007 Mercedes Benz ML350[/color]
Threads: 224
[quote name='Anchorman' date='Jul 12 2006, 05:37 AM']I'm guessing that your question was more aimed at "What was the first modification you did?"
[right][post="23952"]<{POST_SNAPBACK}>[/post][/right][/quote]
BINGO, but I'm enjoying the way many interpreted the question and I find the lists interesting.
Thanx guys
Threads: 46
I've been slowly doing maintenance stuff mostly, but my first mods will be
ROW lenses
airbox + K&N + chip if my ECU can take it
thinking about painting my front brake calipers so I have 'little reds' <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Sean - San Francisco
Threads: 5
The first thing I did was remove the outrageuos 12" sub-woofer with 1 - 200 watt 4 channel amp and a secondary 2 channel amp (wattage ?) that was custom installed in the rear. This was part of a $7409.00 voice activated system that included a 12 disc CD changer (installed in DS rear well), in-dash DVD LCD with GPS navigation, new interior speakers throughout, back up camera and 2 way alarm. Sounded amazing (but very embarrassing) - I was the envy of every 18 yr. old kid on the block. Other than that, the car was confirmed in mint condition with thorough PPI, full documentation with stamped dealer book and 58K km put on by 1 previous owner. Car is fantastic! I wasn't so fortunate though when I bought the S2 cab a few years earlier - spent about $2K in the few weeks.
P.S. Anybody looking for a "very cool", blow your mind, cutom fit sub-woofer with amps - CHEAP
Paul
'92 Coupe, Amazon Green, LSD, 17" C2's
'90 S2 Cabrio, Triple Blk
