04-18-2007, 11:30 PM
Got my car back from the shop after having the clutch hydraulics and hose replaces, new shocks, and new front tires.
First off, they didn't do anything with the variocam because of the potential of it turning into a huge expensive job. Basically the mechanic told me the belts will need to come off, the cams, etc, which is fine. Since the belts and cams are off they can go in there and redo the front seals to stop the oil. While they're fixing the front, they might as well fix the rear too: replace the clutch to stop the oil from coming out the rear. However, he also said that if they need to replace the variocam tensioner, it will basically double the cost of that particular trip to the shop. The part weighs in at something like $1500 + labour.
My question is, do those things fail often? Is it wise to replace everything right then and there? Or can I keep using the old tensioner and save myself a lot of money. Maybe get it refurbished?
Anyways, they did replace the clutch hydraulics (no break lines because they're on back order, doh!) The clutch pedal feels SO much better; there is no play at the top, and smooth constant pressure through the entire range of travel. The mechanic said there was a slight leak in the boot of the slave (I think), and everything looked pretty old. So I'm happy I got it replaced, who knows how long it would have lasted. Next up, the clutch! (see above <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
Finally, the new suspension makes the car feel a lot smoother, and more responsive. Its not as jarring going over bumps. Up front I have Koni strut inserts (86411414sport is the part number on the bill) and stock springs, and in the back I have another set of Konies (80401035sport). The car definitely drives better, they're set at a medium setting. Are these height adjustable? I wouldn't mind lowering the car just a bit. Maybe stiffening it up while I'm at it. Hey Flash, got any spare springs left? <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
In the meantime, its time to start saving and order that RSBarn flywheel and clutch kit, and get this engine to how its suppose to be: leak free, and worry free <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Overall this trip cost me $900 in parts, $2000 in labour, and $400 in taxes. Yikes, these are some hefty green fees.
Edit: I should add that he was pretty impressed with the SS clutch hose <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
-Ren
93' coupe, grand prix white, black leather, 17' white rims, pinstripes, Koni strut inserts, Design 1 strut brace, Design 1 lower casis brace, SS break lines, SS clutch hose, RSBarn flywheel, Airbox mod with velocity stacks - SOLD
(This post was last modified: 04-18-2007, 11:50 PM by Renalicious.)
