Threads: 56
Is it safe to unplug the variocam connector on the cam cover as a way to determine if the variocam system is operational or not? If so, what kind of behaviour is to be expected, assuming that vc was operational to begin with?
Threads: 177
If you hook up a test wire to the leads fitted with a small 12V bulb that you can lie under the wipers, you can then just drive the car and see for yourself. The bulb should come on and stay on from 1500 rpm to 5000 rpm. It will be off above and below those limits.
Kim Strong, Nova Scotia
2022 Mustang Mach-E
Threads: 177
I tried it and it does work.
2022 Mustang Mach-E
Threads: 30
Better than a test wire, if someone were to productionize a wiring harness that plugged in-line with the variocam connector and drove a nice LED indicator (or series of LEDs to show magnitude), it could become a must-have piece of 968 equipment.
Apparently, there are a lot of latent, undetected failure modes to worry about. This was a topic of discussion at the Hershey tech session that Pete provided.
It would also look way cool [img]style_emoticons/<#EMO_DIR#>/cool.gif[/img]
Just a thought. I'd buy one.
Jamie
Threads: 56
The problem with said test is that it will not tell wether the system is working or not, but only tell you that the DME tells the solenoid to open the flow of oil. Or is it so unlikely that the mechanical part of the variocam can be stuck or that the solenoid itself is broken? My seat-of-pants aren't very reliable but perhaps a WOT pull in third from 2000 to 6000 rpm with first the connector attached and then a new one with it disconnected. Have a friend time both runs and compare. Not fancy but perhaps it would suffice.
Threads: 48
Hmmm...I always thought the sudden burst of power at 4000 revs was due to the variocam [img]style_emoticons/<#EMO_DIR#>/unsure.gif[/img]
Johann van Biljon
'60 Aetna Blue 356B T5 Coupe
'79 Silver 924 5 speed - Sold
