09-11-2011, 11:19 PM
Even though I'm converting my car to a mostly-track car, I'd like to go ahead and clean up the valve cover, as mine looks pretty dingy. I'm not normally into this kind of thing, but then I got to thinking, when my car becomes such a track terror that other drivers will want me to prove to them I don't have a turbo V12 under the hood <img src="/forum/images/smilies/968/tongue.png" class="smilie" alt="" /> , I want the engine to look presentable, especially under the new D1R cross-brace I have on order.
Here's a picture of my valve cover:
I've cleaned it up the best I could with solvent, but as you can see, it has some deep stains. Without going to crazy (i.e. no crinkle black finish, chrome, or any other type of plating), what are some of the things you guys can recommend that I can do, preferably at home, to spiff it up? I don't mind spending some time, because I'm waiting for parts to arrive, but I don't want to spend a lot of money, because after all, it is going to be primarily a track car. I was thinking maybe hitting it with a soft, drill-mounted wire brush, then either painting it, or just clear-coating it. I know Scott Collins recently bead blasted his, and it looks incredible, so that is an option, but if at all possible, I'd like to reserve expenditures to things that actually make the car go faster, so again, I'd like to see if I couldn't do something at home. Thanks in advance.
By the way, the fuel rail cover was painted red by the <acronym title='previous owner'>PO</acronym>, and it looks decent, so I don't need to do anything to it.
