Tranny oil plug
I want to change the tranny fluid. I went to remove the fill plug on the tranny's side and I couldn't get it to move, even using some penetrating oil. Am I doing something wring or is the plug just stuck? Any suggestions?
They're very stubborn. Last time I did this I snapped my 10mm allen socket in 2. But I did coat the threads with anti seize when I reassembled it. Hopefully this does the trick for the next oil change.
use a breaker bar or equivalent on it, it will come off. make sure you turn right direction, counter clockwise.
and use anti-seize on the threads when you put it back in
OK, thanks for the advice. I will try it again tomorrow. I just wanted to make sure I wasn't doing something wrong.
try tightening it first to "wake" it
also, try hammering on the socket to "wake" it (be sure the allen is FULLY inserted)
You might also try a heat gun; that has helped loosen stubborn bolts for me on occasion. I don't think there's any risk of igniting anything in the area you're working. Good luck.
Last Post by MCL968
04-02-2016, 02:03 PM
Last Post by robbgerard
09-19-2014, 12:57 PM
Last Post by MCL968
11-26-2013, 08:06 PM
Last Post by Cloud9...68
02-14-2011, 01:56 AM
Last Post by barth7
06-13-2008, 09:29 AM
Last Post by barth7
05-14-2008, 09:20 AM
