02-04-2007, 07:03 PM
[quote name='bigmike' post='30279' date='Jan 28 2007, 01:04 PM']Also, I want to change the transmission oil in my Tiptronic transaxle. The specs say to use "Hypoid transmission oil SAE 75W90". Is Hypoid transmission oil a fancy name for "gear lubricant", and can I just use a good synthetic "gear lubricant"?[/quote]
FYI. I did some research on this, and found the answer. The answer is that if you buy "gear lubricant" or "gear oil" and it is rated GL-5, then it is indeed "hypoid transmission oil". The GL-5 rating means that it is designed to be used with the extreme pressure (EP) associated with hypoid gears (the gears cut with a slight curve).
Do not use GL-4 rated gear lubricant in the transaxle, as it is only rated for straight cut gears, and will not survive the extreme pressure produced by hypoid gears.
I bought a quart of Valvoline GL-5 fully synthetic gear lubricant, and will be changing it this week. The specs say it only takes 0.7 liters, and it looks like it will be fairly easy to do. If I notice any difference or run into any strange encounters, I will let you know.
