Threads: 4
Is there any trick to replacing a tie rod assembly? My concern it getting it loose from the steering rack. I have read that some people put a wrench on the flat portions (if they exist). Some remove the entire rack and bolt it in a vise. I have also read that the steering rack can handling the torque and you can just put a wrench on the inner tie rod and turn away. Anybody have any experiences?
Tim K.
93 968 coupe
90 944 cab
Threads: 4
earossi,
Are there flats on the steering rack to hold it while you loosen the treaded ends? Some say to not put any wrench on this shaft as you might put a nick in it and cause it to leak. Maybe it will become obvious once I get under there and look. Did you put any lock tight on the threads when you reassembled?
968gene-Vertex had them on a blow out special. I think the price was $48 each. First they sent me ones that were too short but have since sent me the correct ones.
Thanks for the help.
Tim K.
93 968 coupe
90 944 cab
