Threads: 8
I believe any small spare wheel is only rated for not more that 40mph. Our spare can be deflated enough to fit back into its cubby hole. You remove the air valve use a length of rope, run it around the tire, and use a tire iron or part of a broom handle to twist the rope to draw down the tire. This will compress the tire and you reinstall the valve before releasing the twisted rope.
Cheers,
Larry
1992, 968 Cab, Horizon Blue
(This post was last modified: 11-30-2013, 07:27 PM by
Grandpa#3.)
Threads: 44
1993 Wimbledon Green M030 Coupe! D1R Stage 3 Super Charger; Short Shift Kit; AC Tensioner; Splitter; Mesh Grille; Exhaust Shield; Caster, Tower, & Firewall Braces
1993 Wimbledon Green/Cashmere Coupe; D1R Short Shift Kit; leather dash; new paint; 52k miles
1987 Guards Red 928 S4; sport wheel; limited slip; heated seats
Threads: 15
I had a flat today on the worst day possible, on my way to the airport. When I began inflating the spare it only popped on one side and I was afraid it was going to blow before the other side popped. I let it go and it inflated properly. Drove about 3 miles to long term parking and went on my flight. After reading that many of you had trouble deflating it I'll have to deal wth that when I get back. If it doesn't deflate proper I'll take a ratchet strap and force it. My only regret is the spate isn't virgin anymore but oh well. Spares are made to be used.
I was really astonished at how light that spare was though. I wonder if those spare rims are forged and if so, might be worthwhile to use as everyday rims on A smaller vehicle.
Current: 1994 968 Coupe, 1987 944S, 2004 VW GTI 1.8T, H-D XR1200
Previous Porsches: 2000 986S, 1974 914 2.0 Blue, 1974 914 2.0 Yellow, 1970 914 1.7, 1985 928S
Previous non-Porsche favorites: 1974 Early Bronco, 1975 Cosworth Vega, 1977 Trans Am 6.6L, 1973 Karmann Ghia, 1983 Supra (turbocharged)
Threads: 167
As I understand it, these spares are in high demand in the 356 crowd.
Threads: 167
There are 2 different types of spares (steel vs. aluminium, also # of holes?)..look up 356 outlaws.
(This post was last modified: 07-08-2015, 01:06 PM by
94SilverCab.)
Threads: 15
My 944S has a steel spare while the 968 has the alloy. I really didn't want to use the spare since it was never used but I was in a pinch. On the alloy 968 spare it's interesting that they set the offset just right so it sits relatively flush with the body and doesn't give that look of it riding on bicycle tires like most donut spares.
(This post was last modified: 07-09-2015, 12:24 PM by
JTP.)
Threads: 49
I have never heard of anyone trying a donut spare on a 968. I would advise against it for a number of reasons. First, the smaller diameter would result in an already low car being dangerously lower on whatever corner you put the spare. Second, the narrow tread combined with the changed ride height would make the car squirrelly at any speed above walking. Finally, where do you plan to find a 5x130 donut in the proper offset? Sourcing and stowing such an animal might prove to be impossible.
I would suggest getting one off of an older Boxster or 944. There are lots of them in junk yards, and picking up an aftermarket compressor to inflate the tire should the need ever arise.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
