Tail light removal
Anyone have a DIY \ pics, to remove the tail lights. I thought it would be easy but started to do it and can't figure out how. Any advice or pictures are greatly appreciated.
TIA
Josh O
Very easy - there is ONE hug 'nut' that you remove, then the tail light should come out.
There may be some dum-dum in there keeping it stuck in...
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
those plastic nuts are covered by a rubber cap, so when you pull back the trunk carpet you may only see the top of the rubber cap - pull/wiggle the whole rubber piece out...and don't be shy, some may require a bit of wrestling.. and the head of the nut will be exposed - start unscrewing it ( it will seem like it takes forever..) but eventually the light cover and tail light assembly will fall back, the wiring should keep it from falling on the ground, but keep a hand under it just in case..
This is the nut that must be unscrewed:
[Image: Light%20Removal.JPG]
Wow guys thanks for the insight. maybee I'm the dum-dum, I would have had the bumpers and fenders off before I saw that. I will give this a try tonight.
[quote name='Josho' date='Aug 23 2005, 05:46 PM']I would have had the bumpers and fenders off before I saw that.
[right][post="9056"]<{POST_SNAPBACK}>[/post][/right][/quote]
Not so far-fetched ...I'm a little surprised Porsche did not actually design this assembly in a way that would require half of the car to be taken apart in order
to change a $ 3 part. <img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" /> I guess they reserved that thrill for the engine / power train only... <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" />
So easy, thanks for your help guys, all the signal bulbs look fine so now I'll change out the relay.
Thank Gwad for this search feature. This old post just turned my repair job from a frustrating hour long search party to a 5 minute job. Thanx to all who gave the input above. <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
[quote name='ds968' post='9018' date='Aug 22 2005, 05:13 PM']those plastic nuts are covered by a rubber cap, so when you pull back the trunk carpet you may only see the top of the rubber cap - pull/wiggle the whole rubber piece out...and don't be shy, some may require a bit of wrestling.. and the head of the nut will be exposed[/quote]
interesting... my car doesn't have rubber caps over these nuts. perhaps a PO lost them? I assume you're referring to part number 9 below?
what function do they serve? sound insulation? water?
Yes, item 9 is the rubber plug. Probably both sound and water insulation and exhaust gas too. Good luck, Bob Blackwell.
I have been fiddling with one of my brake light sockets that does not hold the bulb in good contact and thus it does not work sometimes. It you have a light out and the bulb is good, the socket might be the culpret. Check it over thoroughly.
Cheers,
Stephen
Stephen G.
Moscow, Idaho
Last Post by lbpesq
04-16-2025, 12:42 PM
Last Post by LES
10-07-2018, 06:52 PM
Last Post by archemist
09-03-2018, 06:26 AM
Last Post by robbgerard
02-03-2018, 11:46 PM
