Threads: 9
Have a look behind the carpet on the rear panel. Mine has a rubber bung behind the taillight unit which comes out to reveal a nut/bolt/screw (it's a long time since I had it out and I think it might be slightly different depending on the year). Remove that and you can remove the taillight from the rear of the car.
Michael
'95 968 Sport
'73 VW GT Beetle
Threads: 49
While you are at it, now is the time to shim the light so it sits square in the body. Most tend to droop over time.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 49
It must have been hard to exhibit such restraint! One of the shortcomings of this forum is its often lengthy and pointed technical dialogs.
I appreciate that you took the discussion in hand and resisted the temptation to do a blow-by-blow analysis of the taillight issues of the 968.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
