Threads: 51
I finally got tired enough of the frik'n airbag light that I decided to do something about it - got the codes read and low and behold it said one of the front collision sensors needs attention.
Didn't find anything here about the issue - but did find a discussion on rennlist by some 929 owners. Look in the 928-forum - "right front crash sensor" is the post title.
Our part number is 928 613 220 02 - so probably the same part as the 928.
I'm just looking for guidance here if there is any on offer. Has anyone found the part on our car? Repaired or replaced? If the 928 is any guide that sucker is buried pretty deep up under the dash.
Threads: 51
Ha! OK - will do. Holy smokes - this must really be uncharted territory. [img]style_emoticons/<#EMO_DIR#>/ohmy.gif[/img] Into the breach, then. I'll let you know what I find out.
