Sensor Diagram ?????
Hope you guys can help out a new owner.....I've searched the forums ....but can't seem to find a diagram that shows the locations of all of the 968 sensors.....
Are you looking for a sensor in particular or just curious as to where they are? Im sure myself and a few other members could describe the location of a specific sensor to you, if you are looking for one.
[quote name='968workaholic' post='43563' date='Nov 14 2007, 02:56 PM']Are you looking for a sensor in particular or just curious as to where they are? Im sure myself and a few other members could describe the location of a specific sensor to you, if you are looking for one.[/quote]
Actually ...I'm looking for knock sensor#1....but I'd like to know where they all are
thanks
The 2 knock sensors are under the intake manifold and fuel rail. You can see them through the manfold splits and are held in place by a 13mm nut.
Kevin
[quote name='kwikt' post='43576' date='Nov 14 2007, 08:50 PM']The 2 knock sensors are under the intake manifold and fuel rail. You can see them through the manfold splits and are held in place by a 13mm nut.
Kevin[/quote]
Which one is #1.......
thanks
No.1 should be closest to the front of the engine in between 1 and 2 cylinder.
[quote name='kwikt' post='43584' date='Nov 15 2007, 06:56 AM']No.1 should be closest to the front of the engine in between 1 and 2 cylinder.[/quote]
thanks....
Last Post by apex
06-20-2010, 01:57 PM
04-18-2008, 02:17 PM
Last Post by Etnier
06-14-2006, 02:26 PM
04-24-2006, 01:56 PM
