Threads: 15
Cloud thanks for the tip about Travis at Rennbay. I'll hit him up with a few questions if, once I flip my ps pump vanes and get the car back on the road, it still steers the same. I would think there's no way the problem can be rack-related, as the steering felt exactly the same even after putting the new rack in there. So it seems I've replaced a perfectly good rack, as it wasn't leaking or anything when I pulled it.
A note for anyone installing a replacement rack from AutoZone - you'll likely receive a 944 rack, like I did. It fits fine, but the groove in the splined shaft coming out of the steering gear is 180˚ off from a 968 rack. I had to flip my steering wheel 180˚ once everything was together.
-Austin
'94 Black/Tan Coupe
Threads: 22
I think Lear's problem is the bit where it says "Removing and installing manual steering gear". The procedure is the same for the powersteering gear.
There's a small black threaded plastic cap on the alignment hole. You remove that, get the dimple in the rack aligned with the hole, screw in the tapered bolt to hold the rack centered relative to the housing/car body, then adjust the tie rod ends as Flash has said. Simple as that. No fuss, no mess. Car tracks straight and centered.
Why might you need to adjust the steering wheel? When you take out the pinion gear during the rebuild, it rotates. Getting the flat section on the upper part of the pinion exactly where it was when you started is a PITA. If you don't get it exactly right your steering wheel will be off center.
I opted not to worry about that too much as I knew I'd be replacing the steering wheel anyway and could correct it that way.
-Matt
