Threads: 51
I have my car up on the rack looking for reasons for a shimmy I have been getting in the front end. It is pretty bad at first drive of the day and then seems to go away pretty much. I thought I was going to find worn tie-rods, but I found the rack actually moves from side to side about 1/8" each way when I move the wheel back and forth. The rubber bushings look OK, but I guess a new set is in order.
Anybody done these on their car? I wonder if the hoses have to come off the rack in order to pull it out far enough to put in new bushings?
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 51
I thought about tires as well. That explains it going away after a while. The tires are new, but I guess that doesn't count them out.
Flash, I have new castor blocks and the control arm on one side was replaced as well. I checked both ball joints a short time back and they were fine.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 51
I rebuilt the struts with new Koni Sport inserts a short time ago. I reused my upper strut bearings and they had the weights on them, however one of the weights snapped off as it was just glued on. I have seen some with rivets holding them on, but not mine.
I don't see how those weights could have any effect on the shimmy though.
I just looked up the rack bushings and there are Delrin units available for $79 each. WOW! OE rubber units are only $8.95 each.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 142
I had a bad steering rack about 1.5 years ago. It was so bad that I could turn the steering wheel 90-180 degrees and the car still went straight. Scary? Not so bad at 5-10 mph -- hey we are car guys right? One of the rack mount bolts broke. The movement also tore the high pressure fluid hose. Replaced the whole mess.
Roland
Roland
Threads: 51
So I only need one of the expensive little fellows......good to know. Thanks
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
