03-07-2008, 01:44 AM
Well, I just had the steering pump replaced along with the tank and both hoses to fix a pump leak.
When I picked up the car there was a problem. The steering felt like there was no assist at all when I pulled out of the parking spot.
Here is what I have found:
Steering feels normal when I am rolling, regardless of rpm;
When I am not rolling the power steering assist seems to slowly leave when I am stopped after 10-15 seconds. If I bring up the revs when standing still, the steering does not improve and remains difficult to turn. As soon as I pull away and reach 5-10 MPH, the steering goes back to normal.
So, it is not rpm related but seems to stiffen up only when I stop.
I am not leaking fluid from anywhere in the system and the PM said that it had good pressure and when he test drove it it felt fine. It must have changed while sitting for 2-3 hours.
It is not pressure in the pump because if I increase the rpm's the pressure should rise and make the steering ok, but it does not improve the problem.
What does stopping have to do with power steering viability?
My PM said to drive it for a couple of days to see if anything changes and that he says it must be a bad pump. The pump guy says that it must be the steering rack. Finger pointing at my expense.
Any ideas? Has this happened to anyone else on the board?
Brian
Brian
(This post was last modified: 03-07-2008, 03:24 AM by SILVY968.)
