[quote name='Caracal' post='41036' date='Sep 10 2007, 10:03 PM']The speedometer and odometer stopped working on my '93 Cab. I have had the instrument gears replaced. Does anyone know how to test an ABS sensor using a multi-meter?[/quote]
Not sure if you posted on Rennlist as well, but if you did sorry for the repeat. You can see if there is voltage going to the sensor from the computer, but not coming out with a DMM. If you have a oscilloscope or and oscilloscope function on your DMM then you can actually see the signal being put out. Did you see if there were any codes? I would think that if a sensor was malfunctioning the ABS light would come on or a code would be set. BTW DMM stands for digital multi meter.
