Threads: 24
Hi,
I am a new member of this forum and I have to say it has been a great help to me! (airbox, chips), thanx !
At the moment I am looking at a sound pipe for my 968 conv. This sound pipe replaces the centre muffler (after the cat) my main goal is to get a better sound out of my car, any power gains are a bonus....my question is how will this sounpipe affect the performance? has anyone tried this before? It bolts directly to all the original flanges etc. so no hassle with the fittings <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Thank you in advance,
Rutger
1992 Amazon green convertible. Cargraphic cat. back exhaust, RS Barn/ Design 1 Racing lower & upper strut brace, RS Barn stage 1 Chip, Airbox modification, M030 Swaybars.
Threads: 51
wow, what is this sound pipe? I have done away with my mid-muffler with a straight pipe. It has made the exaust louder,but with a raspy rasberry at high RPM WOT. I had thought about adding a glass pak to take off the edge, but have done nothing yet. I would welcome a sound increase ....let us know wht this sound pipe is all about.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
(This post was last modified: 02-23-2007, 11:35 PM by
Ryan.)
Threads: 24
Flash,
I was told that all the parts bolt/ slide into the original system, so there should be no problem fitting this pipe. I agree that a RS Barn system would be the best option but, It would cost me a lot of Euro`s to get it shipped here into the Netherlands, not to mention the tax (19%) <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
I can take some pictures of the piece by the end of next week, i will post them on the forum!
Regards,
Rutger
Threads: 24
Hello,
I just got my Soundpipe for the 968 in.....see the pictures <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
As it turns out it is made bij Cargraphic, and i think it looks pretty good, I will get it under my car this weekend, I will keep you posted!
Regards,
Rutger
Threads: 24
According to the company it should slide into the original pipes coming from the rear muffler, just like the original section does...to be honnest i did not look under the car to verify this....
Threads: 24
Flash,
I just looked under the car, and indeed it is welded.... so this means I will be doing some welding and cutting <img src="/forum/images/smilies/968/mellow.gif" class="smilie" alt="" /> any tips to do this the best way? or should i order the muffler that is also availble from cargraphic?
here is a link of the exahaust options for the 968:http://www.cargraphic.de/index.php?/s,6,7,18,720,738/&start=3
Regards,
Rutger
Threads: 35
Hmmmm... if one looks closely at page 59, #202-05 of the PET, the 968 muffler is shown as having a square 4 bolt flange to mate to the catalytic converter...
It appears from the above photos that there is a square four bolt flange that "could" possibly bolt to the Cat, at the front of the "Sound Pipe", thereby eliminating all of the muffler and resonator. Not sure that is going to be the best for performance, but I suspect the 968 will definitely "sound" racier!!!
In short, don't cut anything until you remove your old system and test fit the new pipe... and let us know how it works for you! Oh, and use LOT'S of PB Blaster to loosen up the old muffler bracket bolts first!
Threads: 35
Ah Ha! Yes I zee vat you meen!
The usual case of rectal obfuscation applies...
just need to get my head out of my... well, there you go!
Just start talking exhaust pipes and I get all confused!
Threads: 51
Rutger,
This is pretty much what I have done to mine. The rear muffler on the 968 is pretty loud without the mid-muffler. Not bad sound at low to moderate throttle, but kind of harsh at wide open.
A muffler shop could easily put this on for you. You might want to look at another muffler, in which case the pipe you have there could be substituted with a single tube from the CAT back to the aftermarket muffler.
Flash is right to look for a proven system that does not rob any power. Hope this helps.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 24
Ok, The "sound pipe" is fitted. It took me the best of my weekend, but hey, a hobby consumes time and money. <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" /> In order to get it right I made a coupler, so that I can fit back the original centre muffler(the front was bolted to flange from the cat, so no problems there). In time I will get the rear muffler as well and get it all welded up....
The sound it makes is not bad at all, it sounds a bit like my father`s 964 C2 (also modified exhaust). Only when the trottle is all the way open there is a loud rasp...
Performance wise I can not tell there is a really difference, a dyno run would be the best option. I also think that Cargraphic (german porsche tuner) knows what they are doing (any other opinion is welcome) I will send them an E-mail and ask if they have any charts.
Regards,
Rutger
