Should I be using coolant?
100+ degrees, very muggy - run my A/C all the time, drive her hard (as I should! <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" /> )
I can't find ANY coolant leaks anywhere - why should I have to be adding about 10oz or so of coolant every two weeks? (approx.)
I checked the oil, no coolant there...
Anyone have any thoughts? Does your car do this also?
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
I recently had a somewhat similar happening. After hard track sessions the car would push water out of the overflow on the coolant tank. I was always having to add water. I was worried it was the headgasket or a cracked head. I bought a block leak checker at NAPA. It basically checks if there is any exhaust gas in the coolant. I was worried the system was being overpressurized by a headgasket leak - it wasn't. You might want to check that out since it is only about $50.
Anyways, I changed the waterpump and everything is normal again. I couldn't see anything wrong with the old pump but it is now fixed.
Eric
Interesting because the car just had a new water pump in January.
I'm going to borrow a coolant pressure tester from the local p-car shop.
I'll check it tomorrow and let everyone know how it all goes...
Michael Sorbera
2002 VW Beetle TDI
08-26-2021, 12:56 AM
Last Post by MLB
05-15-2016, 12:34 AM
Last Post by Nenehubert
10-22-2012, 10:00 PM
