I have an idea for a steering column that has precise turn characteristics with no play but isolates the steering wheel from road jolt (fingers crossed). Spoke to Pete at RS Barn about it and I will be sending him some sketches to see what he thinks, could be a good idea for track cars on rough corners. I also have an idea for a replaceable ball joint on the lower arm which can be removed in situ and also height adjustable for lowered cars as that allegedly is a cause of failure on some set ups. Don't throw the kitchen sink at me over that comment, I'm only taking into account what was said on Blaszak.com. If the ball joint idea is good then there would not be any need to do exchange deals on lower arms, ONCE YOUR ARMS ARE MODIFIED to accept the new balljoint assy. Pete was saying that you can't get steering knuckle arms any more but RH ones are available in the UK. Could someone post a closeup of a LH assy please,
assuming that its different.
