10-10-2009, 09:19 PM
Hey, how does one edit the title ? Clearly I meant gremlins, not gremlis and Koni, not Knoi [img]style_emoticons/<#EMO_DIR#>/rolleyes.gif[/img]
A couple of months ago the adjusting knob of one of the Konis' ( front, driver's side ) suddenly froze in place. No idea at all what could possibly have triggered that but I tried to turn it, in both directions, and even when applying a lot of force with a pair of vise grip pliers it simply did not budge..it's as if it was welded in place. But the ride remained unaffected so I figured there's no rush, it's still set where I had it before so I'll leave it alone for the time being and at some point when I get around to it I'll just order another cartridge and replace it. In the meantime every week I'd try ( in vain ) to see if maybe all the bouncing around from driving hundreds of miles has loosened it. Nothing [img]style_emoticons/<#EMO_DIR#>/mad.gif[/img] . Solid as a rock. Even sprayed a bit of WD40 on it, and let it soak in for days , but no chance.
And then half an hour ago as I was checking the oil, the ps and other fluid levels, etc, just for the heck of it I gave it another try with the pliers, and as inexplicably as the time it froze, it started working as if it never had a problem; same feel to the turn resistance in both directions, smooth, no grinding noise, and once again adjustable as it was meant to be.. WTF ? [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img]
(This post was last modified: 10-10-2009, 09:23 PM by ds968.)
