[quote name='xrad' post='54646' date='Jun 12 2008, 05:16 PM']good luck to your daughter!
Do the impeller vanes face the right way (if it was a rebuild pump)?
Does the pump belt turn the pump correctly?
With the pump off, use a mirror and look in the passages, if possible. Then use a high pressure washer and jet in the inlet or outlet of the block. See if flow runs in one and out the other.
Check all coolant hoses for patency. Even the little ones to make sure all the air you can get out is really out
Just have to take this one step at a time until it is solved.[/quote]
Thanks for the kind words about my daughter. She's been essentially incapacitated for about a month and a half, and nobody can figure out why. She lately seems to very gradually be getting better, but her rate of improvement can best be described as "glacial," unfortunately. And this is a kid who won the first ice skating competition she entered just before she got sick.
I wish I had taken a closer look at my old water pump before sending it back for my core charge refund, because now I don't have anything to compare the reman pump to. To answer your questions, xrad, the pump's impellers actually point radially from the center to the edge of the impeller. To my surprise, they aren't curved in one direction or the other. Is this normal?
I'm pretty sure the belt is turning the pump correctly, because before I loosened the belt, I couldn't turn the pump by hand, so it's definitely applying plenty of pressure to the pump's roller. Overall, I'd have to say the pump looks very sturdy and well-engineered. In fact, Chuck from Paragon told me that compared to a new pump, the reman one to him looks like it has a more substantial casting, if that means anything. Also, I just got done placing it in a pot of boiling water to make sure the impeller is not coming loose of the shaft when it gets hot, and it isn't. I'm about as convinced as I can be at this point that it's not the pump, especially since the car started running warm long before I replaced the pump.
I don't have a high pressure washer, but I'll try flowing water through the block. I understand this is an important step, but I've been putting it off for two reasons: First, my driveway is on a slope, so I can't roll my car onto it, so flow testing will flood my garage, and second, since my block doesn't have a drain plug, I'm afraid that I won't be able to get the non-DI water completely out of the block.
I'll take another good look at the hoses. The two big hoses connecting the radiator to the enginer are fine, as is the small diameter hose connecting the bottom of the reservoir to the fitting on the front of the water pump. I'll check the rest as well.
Does anybody have a good diagram describing the path of water flow through the cooling system? There isn't one in the shop manual.
Thanks again for all the suggestions.
