05-13-2010, 02:20 AM
I've been hesitant to post another thread on this, because I'm afraid of what the answer be, but I'm beginning to resign myself to it. For over a year now, my car has been running hotter than it did in the first few years I owned, and I believe hotter than it should. I've replaced numerous thermostats, and most recently installed one from RS Barn, into which they drilled a half-dozen small holes near its periphery to allow a small amount of coolant to flow past at all times, to allow more gradual warming of the engine. I simultaneously replaced the coolant reservoir cap with one from RS Barn. The car doesn't consume a dop of coolant, and I've recently bled the system when I replaced the latest thermostat. The fans work perfectly - both come on at their relative prescribed cues, and they both blow up a storm. I've had oil analyses done as part of my last two oil changes, and neither showed even a hint of a trace of ethelyne glocol. I taken the radiator to a shop to have it cleaned out (though they told me it was perfectly clean and free of any obstructions of any kind when I brought it to them).
It gets particularly hot when I drive it aggressively - one trip to the redline, and the temperature gauge is close to the 10:00 oclock position (upper line on the gauge), though when I ease up, it drops back to where the needle is slightly above the 8:00 oclock line. Driving around town, even on a hot day, in traffic, and it stays at 9:00 oclock or slightly below. When I first got the car, I swear it never got above 8:00 oclock, even during aggressive driving. Buyt even on the coldest of days (below 30 degrees F), it never stays below the 8:00 oclock line, which seems very odd.
What concerns me is that after the engine is fully warmed up, the fat radiator return hose (on the passenger side) never feels very warm, which tells me (I think) that I'm not getting enough coolant circulation. I wish there was another 968 nearby I could compare my by-feel radiator hose temperature to, but the other one is much hottr than the fat one on the passenger side, which doesn't seem right. .
This brings me to the part I'm dreading. I replaced the water pump as part of my belt change two years ago with a remanufactured one from Paragon. Soon after installing it, the car was running hot, which did turn out to be a bad thermostat, but in the course of troubleshooting the problem, I removed the water pump to make sure the impeller wasn't free-wheeling on its shaft, and it wasn't - couldn't have been any tighter. I even put the water pump in a large pot of boiling water and tested the tightness of the impeller at close to operating temperature, and it was fine. Once I got a good thermostat in there, it ran fine, even at the track on some pretty hot days.
Based on my current symptoms, do you guys think the water pump could have failed? It's definitely not leaking, and it's such a simple device that I can't think of another failure mode that could explain the apparent lack of proper circulation other than a slipping impeller, which I suppose could have worked its way loose over the past couple of years. Can anyone think of anything else I should check before resigning myself to putting in a new water pump (when I rebuild the head, hopefully later this year)? Thanks.
