06-23-2013, 07:40 PM
Hey all,
Have dug through many threads on this topic and have learned quite a bit. Fantastic forum! Maybe I missed it but I need an answer to these two quesitons; Are the low speed fans supposed to come on when the engine hits operating temp, ie., around 8 o'clock?
And, is the high speed of the fans engaged w/ac or is it the low?
Right now with no AC, the low speed doesn't come on at all. When idling the gauge will eventually hit 10:00 and the high speed will come on cooling the engine and shut off at about 9ish.
With AC, the LOW fans come on right away. I don't seem to have a problem at speed. If I'm cruising around in town I'll eventually have to hit the AC and the gauge returns to 8:00.
I noticed that my coolant was rather low, about a half inch below the minimum. Topped off and it behaves a bit better around town. Still have to hit the AC. Of course when idling it still hits 10:00.
Amongst other work, the WP was replaced in '07. Records indicate it was a Porsche reman.
I went out and bought a laser temp gun. Even at it's hottest the upper hose measured below 190. The bottom hose around 175. but that measurement was taken only about 3 or 4 inhces from the block inlet. Do I need to measure that closer to the rad outlet?
Finally and as always, any help is much appreciated.
JT
JT
Sold
