Scanner tool not communicating with car?
is he using the "hammer"
Sounds to me that there is a ground problem. Due to this problems there is no ground in the 19 pins connector.
Have you checked the voltage from the ground, K-line, L-line and bat +?
For technical scheme from the 19 pins connector etc, read the topic resetting the airbagwarninglight in the sub post that every 968 owner should read.
11-20-2017, 03:52 PM
02-18-2011, 11:19 PM
Last Post by pipes
09-20-2010, 12:29 PM
Last Post by DaveN
11-23-2008, 07:44 PM
