I know we're straying off the original topic of comparison of different exhausts, but I have one (hopefully last) observation: If you extrapolate the very linear portion of your horsepower curve that goes from 2000 to 3000 rpm, the extrapolated line would intersect the HP curve at about 5000 rpm (where you're producing about 225 hp). So, it would seem to me that if you could engineer a nitrous system that squirts enough nitrous to overcome the "pause" in the horsepower curve between about 3000 and 3700 rpm, and then another smaller squirt between about 4200 and 5000 rpm, you'd have a beautiful, linear horsepower curve, without putting the excessive stress on your engine that would come from injecting nitrous at the point where the engine is producing its peak horsepower. I'm not sure nitrous systems are sophisticated enough to do this, and it would probably entail a fair bit of dyno work to get right, but I would think the end result would be an engine with a very nice power band.
Also, you've mentioned that you have a lightweight flywheel and power pullies. In your quest of maximum peak power, do you also have a windage tray? I hear they're worth maybe 2-3 hp at the high end, which would get you close to your goal of 250 rwhp. They are a pain to install, but it might be something to consider.
Thanks for letting me (and others too, I'm sure) live vicariously though your mods while I save up to do the same to my engine [img]style_emoticons/<#EMO_DIR#>/wink.gif[/img]
