10-22-2013, 05:39 PM
When I first test drove my car, the car drove straight, but the steering wheel was somewhere around the 1 o'clock position. I didn't know what was going on, either needed an alignment or something was worn, or a stuck caliper.
Driving it some more, it would go to the center (12 o'clock) position and continue to track straight, I said great! Then it goes to the 11 o'clock position sometimes and still tracks straight. I took the car home and it continues to do that when I drive it.....sometimes it's dead on 12 o'clock and sometimes it's pointed a little to the left or right, can change in the course of 1 mile. But the car tracks straight.
So I bring it to a high end repair shop, they put it up on the alignment machine and check for wheel play first. They show me that the front bearings have play in them (left wheel more than right), and also show me that the rubber bushings have a small amount of play. Very small, and otherwise, everything else in the suspension looked great.
Here is the rubber bushing I am talking about:
![[Image: tn_IMG_2933.JPG]](http://www.audipages.com/968/tn_IMG_2933.JPG)
It's number 10 in the picture below, with the eccentric bolt that goes into it:
![[Image: 401-00.gif]](http://c782349.r49.cf2.rackcdn.com/401-00.gif)
I have yet to adjust the wheel bearings, and I know that could cause an issue, I also just ordered new bushings and eccentric bolts that I will be installing, but does anybody have any other ideas of why the steering wheel might be behaving the way it is?
Thanks!
BTW, I can't believe the prices at Sunset Imports! And you just email them and they email you back. Love it!
Thanks!
