12-20-2009, 09:23 AM
As we all know these cars are beginning to leak due to age, if for no other reason. I have gone though a long period of chasing leaks, and though I have repaired a lot of them, I still have a major leaker that I cannot see to locate. So, I am assuming that it is the oil pan gasket. To date, I have resealed the entire front of the engine and have replaced the rear seal on the lower balance shaft cover. The upper seal (drivers side) seems to be ok, but I am not certain since I can't really see it, though the oil leak seems to be dripping down the front of the oil pan. I also replaced the valve cover gasket when I changed out the cam chain and did the sprocket inspection.
So, I have researched all the search topics on dropping the oil pan, but I have one question that I can't find an answer to. I have a ramp type lift for my car. So, can I drop tne cross member with the weight of the car on its wheels on the ramp, or do I need to jack up the car. This may seem like a fairly stupid question, but I am concerned that when I unbolt the crossmember that the suspension on the car could spread outward, which would be a problem.
One more question is approximately how much does the cross member weigh? I will have the weight of the engine held by a hoist, but I am concerned that with the car in the air, can I safely handle the weight of the crossmember while I remove the final bolts as I stand under the car?
