Threads: 48
My trim piece where all the controls and buttons for the lights resides have cracked. I have bought a new one, but now I am unclear about the procedure for replacing this trim piece. I have done a search here and I could not find anything helpful.
Unfortunately, Clark's garage (
http://www.clarks-garage.com/shop-manual/body-24.htm) and Scotts' DIY (
http://www.968forums.com/index.php?showtopic=4) is not very clear on this section either (No pictures).
I need to know if I have to remove the steering wheel, and wiper/indicator switch assembly to get to the screw that sits next to the steering column. I don't mind doing this, I have done it so many times, I can do it in my sleep. But if i don't have to it would be so much quicker.
Any advice is appreciated.
Thanks,
Johann
PS. @Flash I'm sure you have done this recently with your heated seats
Johann van Biljon
'60 Aetna Blue 356B T5 Coupe
'79 Silver 924 5 speed - Sold
(This post was last modified: 04-12-2010, 12:38 PM by
Johannvb.)
Threads: 48
Anyone? I really don't want to strip away everythig if there is an easier way.
Johann van Biljon
(This post was last modified: 04-13-2010, 01:49 AM by
Johannvb.)
Threads: 48
Just to clarify...
You said "there is a screw at the center of the bottom of the steering column - remove that"
I am guessing this screw is only accesable by going through the rubber bellow that surrounds the indicator stalk?
Can you maybe post a pic of this area?
Thanks.
I always dread triggering the airbag light when I remove the wheel. It hasn't happened yet, but there is always a first time.
I have also come to realize that, like with modding your car, if you replace one warn out/broken piece of trim, you have to replace them all. The soft satin black of the new parts makes the old parts look cheap and ugly.
Luckily the trim pieces are ridiculously cheap, for Porsche parts that is. They are roughtly 25 euro a piece. I guess I will never understand Porsche logic. The one thing that is a genuine Porsche part and unique to the 944/968 is cheap, but a generic Bosch fuel pump rebranded as Porsche will set you back 200+ euro while the Bosch unit is barely 100.
Go figure...
Johann van Biljon
(This post was last modified: 04-13-2010, 04:57 AM by
Johannvb.)
Threads: 48
I have just completed this job and I can now confirm it is impossible to replace the trim pieces around the steering wheel without removing the steering wheel. The problem is that there are one screw per trim panel that sits right next to the steering column and this can not be accessed without removing the steering wheel and the trim cover over the steering shaft.
Johann van Biljon
