Removing LED Lock Pulls?
Has anyone just removed the LED lock pulls and replaced them with the metal Rennline ones? The Genuine Part # 944.637.238.00 is relatively cheap, but I've had a number of these break on me. If I just remove the LED unit by unplugging it does the alarm still function properly?
I have a theory that exposed wires from the LED unit in the door have caused an excessive power drain.
Never replaced them but I have re-re'd them to make sure the wiring is healthy and then epoxied them back on so the NEVER pull off again.
[quote name='DaveN' timestamp='1382383954' post='151059']
Thanks Dave thats a good idea. I like the one and done approach and would prefer to keep the LEDs. These things just seem pretty brittle and I was curious if simply unplugging the LED unit would leave the alarm functional or if some sort or trick was needed like a resistor for the plug that runs to the cars wiring loom.
Last Post by Kim
03-26-2014, 04:31 PM
Last Post by bob blackwell
02-09-2010, 10:02 PM
Last Post by mikeo
04-28-2005, 08:27 PM
