Recovering Interior Vinyl Trim Pieces
Any thoughts or recommendations?
I plan on recovering a few interior trim panels with new vinyl. I've never done this before, but I am guessing heating the panel first to loosen the adhesive is a good start.
I will eventually have to redo my door panels as well as the grey has browned and started to crack. Joy!
Perhaps I will source a used interior trim piece as an experiment.
Any suggestions on an adhesive to use? Which 3M, etc.?
TIA!
Best to practice on something you don't care about first. Understanding how to stretch and curve the material is important. The best adhesive is contact cement. I think 3m has Super 90, or check with your local upholstery shop for what they use for small jobs.
Also consider this: Leather is actually easier to work with than vinyl. Better stretch and conformability.
Dave-
Thanks for the advice. I will check into the 3M stuff as well as try to find a local shop. I will definitely get a sacrifical trim piece to work on prior to doing any of my own.
Regarding the leather- I like leather <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" /> but given the temperature fluctuations here, I hesitate using it. It certainly requires much more care than I am willing to devote. Also, the stuff costs a bunch more and with the recent work I am having done, I'd like to be as thrifty as possible yet maintain an OEM look.
Seems like everything involves some sort of trade-off!
Bio,
I had the tops of my door panels re-done at an upholstery shop for $95 each. This was not a job I would like to try.
I still have lots of discolored panels in my grey interior. Many of these can be sprayed with vinyl paint from what I hear.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
$95 per panel is not that bad, considering a new panel from Porsche is a few hundred.
Did you supply the vinyl/leather, or did the $95 per include the materials?
I knew about the vinyl paint/dye, but I hesitate to use that stuff because I am worried it will flake/sluff/bubble/etc.
The cost of OEM vinyl from World Upholstery is pretty cheap per yard, so I still might give it a shot for some of the other interior panels. I am leaning towards having the door panels professionally done.
For what it's worth, I don't think the classic gray door panels are available any more (new from Porsche that is...).
The shop supplied the vinyl. It was a slightly padded version and worked out well.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Are your interior pieces just discolored, or cracked and damaged? I bought some SEM vinyl paint to recolor the interior in my 944, and that would certainly restore any faded or stained pieces.
Tops of my door panels were discolored and cracked so they had to be replaced. The hard plastic surfaces could be painted.
I don't look forward to removing the windshield surround however. I don't know what Porsche used for their light grey, but it all turns brown. My dash looks like new though.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
I also used SEM to "dye" 2 'A' pillars from dark blue to black. It dried fast, sponge brush application worked great, no flaking or any other problems. I highly reccomend it, it makes a big diff if you are replacing with salvaged parts or just want a face lift for the interior. The stuff expands and contracts with the plastic. It is more of a dye than a paint. It can also be sprayed as it comes out of the bottle.
Is "SEM" a brand of dye or type? Where is it available? TIA
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
worlduph has real good leather/vinyl spray dye
1993 Polar Silver Coupe 6-spd
AIR Splitter, Euro Clear lenses, and 996 shifter
Last Post by BOB968
02-12-2023, 10:26 AM
Last Post by Langley968
07-29-2015, 03:57 PM
Last Post by dry664
05-27-2013, 05:51 PM
Last Post by ether_joe
10-23-2006, 02:05 PM
