Threads: 7
Hi all,
I recall someone deleted the rear muffler to reduce weight....Bob Blackwall?
Something like 30 lbs. Any comments on the the sound and effect on handling?
I am thinking I like to do the same as the Tip is 66 lbs heavier than the 6 speed.
I already removed the spare tire. Anyone know the weight off hand?
thanks
Threads: 167
RS Barn Cat back reduces weigh by about 30 lbs.
No one that I know of has "Deleted" the muffler for both noise and back flow reasons (even full on race cars)
Regards,
Jay.
Threads: 27
I will look forward to checking that setup out myself when I am at the PCA Escape in September. It sounds very interesting.
Threads: 7
Hi all,
thanks for the info....so with the removal of the spare etc. and the muffler, I lose 68 lbs which makes it close to the 6 speed with the same balance.
I gain the balance (like the 6 speed) but may lose some torque/power somewhere. Sound will be sportier but not too loud. I'll keep everyone posted
when I do this.
Interestingly, this started when I removed the front bumper brace (I think Flash did this) and found the balance for the front to be light(er) during
tight cornering (good) but not so good on long sweepers (there is a 270 degree sweeper on the way to work) and I can definitely feel the back more,
I thought a tower brace can help tighten the front.
I put back the bumper brace after 2 weeks and figure some weight removed from the back will help with the balance, especially with the Tip, if I plan to
reduce weight in the front at some point.
Bob, wish I can attend the PCA in Sept. a little more difficult living on Oahu though I wouldn't want to live anyway else. But, IT IS AN ISLAND..nice car with
no where to go. <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
Those lucky ones who can attend the PCA. Please post your observations...thnaks
Threads: 19
Bob....did you maintain the same size pipe?
LuKe
[color="#330099"]SpeedRacer64[/color]
[color="#000"]100%[/color] Pure Stock 1994 968 [color="#000000"]Blk/Blk [/color] [color="#CC0000"]6Sp[/color]
Threads: 51
Funny thing about the 968 muffler...it did not have much to do. If any body has removed the mid muffler and left the rear on, there is a huge increase in sound with the rear left in place. For as big and heavy as the 68's muffler is, it does'nt do very much muffling.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 7
Good to know...thanks <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
Threads: 7
Hi all,
So I finally did it. deleted the rear muffler, the shop put in a Y-pipe that connects to a 2.5" pipe connected to the original exhaust tip.
So, with the removal of the muffler (20 lbs), spare wheel (25 lbs), tire pump (4lbs) = 49lbs from the back. Add back about 3 lbs for the pipes=about 45 lbs
removed from the back.
Sound= nice and deep outside of the car from idle, a little too loud (IMO). In the car (windows closed), resonance from 1700 rpm til after 2000 rpm and again after 3000 rpm.
so I added rubber grommets to attachment points of the rear heat shield which helped with the resonance (since the shield is easy to get to with only the pipe there). I plan
to add more to the other heat shield(s) if i can, to see if it will help more.
normal cruising on the highway (steady rpm) is actually pretty quiet, exhaust sound traveling backwards away from the car maybe? step on gas and I can hear the exhaust
growl. pretty nice......have not really tested to see if there are improvements in the car's pick up. seems to breath easier after 3000 rpm though.
gas from stand still and it gets a little loud as people definitely notice. not as nice as I don't need more attention with a red car.....
cost, $250. To be added to this yr's car expense.
conclusion, I like the sound of the exhaust as it covers the road noise which I really dislike so i can recommendation this mod.
Threads: 7
Hi all,
thanks for the feedback..i kept the original muffler just in case. the shop also mentioned they can add a free flow but I wanted to reduce the weight in the back
as much as possible.
I recall the resonater restricter removal thread, very interesting but too much hassle for me. i need to work on other stuff. the speedometer stopped working and
the gas gauge is not reading properly.
will update with further observations when i get a chance to push the car a little.
Threads: 7
Hi bob, as always, thanks for your help......big plug for your assistance with the tech art splitter info and while I'm at it.
any thoughts on 2 piece brake rotors that works with the stock calipers? that may be a nice group interest.
Anyhbody??
hint, hint........
