Rear Differencial Fluid Change - Capacity question
I just changed the rear differenctial fluid as I wan't sure how long it had been since it had been changed (if ever). In short, fluid looked pretty clean compared not new, but I changed anyway.
I used the 75-90 GL5 per spec. The manual indicated that it should take .7 liters, which should top it off and I'd see fluid running out of the fill hole. Well, I loaded the full quart (.974ml) in there, and it still doesn't seem to be topping nearing the fill hole.
Question is this. Do I leave well enough alone at 1 quart? Or do I go buy another quart and till till it runs out of the drain hole.
I saw some older threads but didn't see anyone referring to having to add more than 1 liter.
I do recall reading in a manual a while back that on one of the early model differencials, the drain hole was about .2 inchies higher than later models.....but I can't find that article any more.
Just looking for some confidence on volumes before I jump back in and drive.
Chris
sorry bout the typos...differential, not differencial. argh....
'13 Lexus GX
'04 BMW 525
'92 968 Cab Black/Grey
Corvette Z06 - Dedicated track car (Sold)
'94 968 Cab-Guards Red (Sold)
According to the owners manual and the technical specifications booklet the "manual transmission with differential" has a capacity of 2.75 liters (=.73 US gal) of 75/90 GL 5.
tom
997 C2S
GMC Sonoma SLS, dd
Miata LS, Cheap Thrills
Acura TL, Wifes dd, zzzzzzz
1993 Red 968 M030, after 18 yrs, gone but not forgotten
Thanks for the quick response.
I was just pouring thorugh some of my old literature, and I must have been looking at the capacities for the automatic/Tips, and not the manual/transaxle(G44).
Guess I'm back to the store for a few more liters. Thanks again!!!!!! That could have been a costly error.
'13 Lexus GX
'04 BMW 525
Its a fill to spill situation, whereas a 944 should be about 6mm below the fill plug.
Yes, took right at 2.6 quarts or 2.46 liters until is started running back out.
'13 Lexus GX
'04 BMW 525
12-19-2017, 12:01 PM
Last Post by kwikt
11-18-2011, 11:00 AM
Last Post by Cloud9...68
02-14-2011, 01:56 AM
Last Post by 968rz
08-05-2008, 10:13 PM
Last Post by Larry Currie
05-09-2008, 12:34 PM
