Rear linkage removal
I'm about to modify the rear linkage on the 968 gearbox for my race car.
I have slop both in the shift block and in the transverse linkage.
Has anyone managed to remove the transverse linkage without breaking the ball on the main linkage?
Take a look at the pictures, in the main picture I want to remove nr 2 from nr 1 and from the gearbox to replace that linkage.
I'm hoping this is possible so I don't have to make a completely new custom setup.
Anyone done this?
Yes , I have done this in a parking lot.. 1st you have to remove the hook pin from the ball on the right side(stationary pin). Then take a screwdriver and pop off that ball cup only. Then go to the drivers side tranny and remove the shift shaft lock bolt(13mm I think) and slide shift er shaft from linkage. Finally remove the 10mm set bolt holding the swival on the tranny shaft. Then slide the entire assembly from the drivers side tranny.
12-19-2017, 12:01 PM
Last Post by KRAG50
08-01-2012, 12:44 PM
Last Post by MATTS92
12-04-2007, 07:16 PM
Last Post by doster
10-31-2007, 12:19 AM
