radio codes
I have a Blaupunkt Denver CD147 and do not have the radio codes or know how to enter them if I ever get them. Can anyone help?
I would pull the radio and see if they are written on the side of the radio. Here is the manual:
http://www.manualslib.com/manual/216616/...e=3#manual
You just put the numbers in using the keypad and somehow hit enter. It's very easy.
93 968 Coupe Six Speed
73 Alfa Romeo Spider
07 Audi S8
Thanks. I have the manual, it doesn't say anything about radio codes, entry, exsistence anything.
I know something would be like an "enter" but not sure what exactly that would be. I am also pretty sure there is some sequence before that to put in and then you enter codes and then push that "enter".
What is the problem with the radio? Did you install it or disconnect the battery and it now says "code" or "safe"?
Has it been in the car for years or was it just installed?
07 Audi S8
you need a four digit radio code then just use the presets on the stereo to enter the code
no enter button required, but if you screw up you only get so many changes and every time you screw up it takes longer to reset -
if you need the radio manual scanned let me know.
I needed to put in a new battery. Got it to work.
Last Post by jsheiry
01-29-2020, 05:33 PM
Last Post by Sculler
10-21-2015, 09:07 AM
Last Post by TheJoe
09-25-2015, 10:49 AM
10-05-2011, 01:57 AM
09-11-2009, 05:00 PM
