Radiator fans come on high when key is turned
I only noticed it the other day because I needed to roll up the windows and close the roof. I stuck the key in and rotated it to "ON" and suddenly the fans came on as if the A/C were on or how they do normally in the summer time after a city drive. It must have just started doing this in the last week or so because I did the same thing (key in, rotate, roll up windows, etc) several days ago.
I've got a couple of notions as to what it MIGHT be (thermo switch, etc) but I'm not positive. [img]style_emoticons/<#EMO_DIR#>/dry.gif[/img]
Help!
Dan
'95 968 Coupe
James Dean
Dan, it most likely isn't the thermo-switch as this makes the fans run all the time even with no key, draining your battery. Could the defrost button be pushed?
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
.. the defrost button ? [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img]
Possibly there's some confusion between the A/C system air blower - which comes on "high" when the defrost button is pushed - and the radiator fans.
I'll have to run out and check to make sure all the buttons and switches are in their proper positions and respond back. Thanks!
Dan
'95 968 Coupe
James Dean
OK, the switches are in the correct positions so nothing out of the norm there. What do you suppose might be the next step???
Dan
'95 968 Coupe
James Dean
see if your ac is stuck on - you should be able to see the clutch engage and disengage
Dan, you don't say but I assume the fans run fast when you turn on the key. They will run slow without the key but fast only when the key is on. Pull the plug at the radiator switch and turn the key on. If the fans don't come on, then you can suspect the radiator switch has a shorted high-speed contact (there's a slow and a high speed contact inside the switch). If they still come on, you can suspect a shorted pressure switch on the AC compressor. There are other, less probable causes too, including wiring faults. If the above didn't help, go to the DIY Library/Electrical ... section, select the Electrical Trouble-shooting the Porsche 968 Cooling System topic, download the file you will find there, and run the diagnostic tests.
I checked the A/C activation. Works as advertised. Thanks Flash.
I pulled the plug, turned the key on and the fans don't come on. Sounds like the radiator switch. A scan through the PET will be next in order to locate the correct part number. Is it the same switch for a 944? I'm figuring this is a fairly common part.
Hopefully, the local parts stores will have one in stock.
I'll update the thread with the results of the repair.
Thanks John.
Dan
'95 968 Coupe
James Dean
The switch p/n is 951-606-481-00. It's not the same as the 944 na's, not sure about the turbos.
08-17-2017, 09:06 PM
Last Post by jfrahm
12-17-2015, 10:40 AM
06-04-2014, 11:48 PM
