Threads: 77
Another issue with the metal impeller is a failure mode of the rebuilds is for the bearing to fail and the impeller to shift forward. When that happens you have a big metal impeller grinding it's way into your block. At that point your block is pretty much toast. It's been a problem in the 928 space, they finally got the major water pumper re-builder Laasco to switch back to plastic impellers. Someone also worked out a way to fix the blocks by mounting a insert onto the block to fix all the damage.
