pedal replacement
My gas pedal had a crack in the plastic hinge so I chose the AJUSA billet aluminum replacements. Gas pedal is great. Tough nylon carrier for the rod and well made hinge for the mount.
The clutch and brake pedals are nicely made but you have to glue in the rubber grips yourself. We will see how long they last in place (I do have some real strong black polyurethane I use to rienforce mounts..from Home Depot paint section..... comes in a caulk gun tube)
to be honest, I had a set from Sparco that were no slip rough surface cast aluminum which were much better.....can't find them though...
here are the parts.....
Nice looking pedals. I've seen them with the smaller rubber dots to insert yourself as well.
OT- I use to have that trackball mouse. Easy on the wrist.
track ball........ <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Last Post by robadams56
07-15-2016, 09:49 PM
Last Post by tamathumper
04-16-2013, 08:05 AM
