KONI STRUTS AND WIELTMIESTER SPRING FIT?
I have came across a set of Koni adjustable shocks and 200lb. Wieltmiester springs that were taken off a 1986 944. I would like to know if they would fit on a 1993 968.
Thank you,
Alex
The camber plates are different, but yes, they should fit, the strut housings are the same.
Steve
I think only the 944S2 and 968 share the same front strut.
the springs and perch on the 944S2 and 968 are different, but the strut and housing are the same. If he already has springs for the setup, he should be fine.
Steve
all of the 944 series cars shared the same outer diameter springs, so they all will "fit", but lengths and rates varied, depending on the year and model, so ride height will change accordingly
if you have the free length of the spring, i can tell you where the car will sit
944 strut will fit, but you will lose the mount for the brake cooling scoop won't you?
The 944 struts have the mount, it's the control arms that don't have the extra brake cooling duct mount.
Steve
Last Post by Roboman
10-02-2020, 11:24 PM
Last Post by gbarrier
06-10-2018, 01:03 PM
Last Post by MCL968
08-01-2017, 02:23 PM
07-08-2014, 12:48 AM
