OVERHEATING!!!!!!!!!!!
I woke up Sunday morning at 6:00 and headed out to the autocross in Miami. I was on the Florida turnpike until 30 mins later I see my temperature rising slowing and the emergency light faded on slowly. I pulled over and I took a look under the hood and nothing was leaking. I hopped back in and kept going, keeping an eye on the temperature. I noticed the temperature would bounce around when im going past 60. I headed home in dissapointment. The water pump was already replaced before this incident. It might be the radiator? any suggestions?
Thank you,
Alex
1993 Guards Red 968 coupe with 6 speed limited slip
do not drive it any farther - you really need to get that sorted out before something very bad happens
it could be a failed pump - it happens with new ones too
could be a stuck tensioner - causes the pump to not be driven
the likely suspect though is that it could be a stuck thermostat
Did you bleed the cooling system?
Are hoses getting hot top and bottom?
Fans kicking on?
I'm betting water pump...
just my $.02 (Got change for a Hundred?)
I'll second the vote for stuck thermostat.
Check Fluid levels when cool. I didn't have leaks but had overheating episodes.
I started to notice that coolant level in the reservoir kept going down, but no leaks
and no coolant on the ground. Eventually I got white smoke upon start-up,
after a new head gasket no problems. Losing coolant without obvious leaks
is a bad symptom.
-sp4149
Last Post by 94SilverCab
03-11-2011, 04:39 PM
08-28-2009, 04:49 PM
Last Post by Jono
03-15-2009, 06:26 AM
Last Post by ira968
08-07-2007, 01:35 PM
06-26-2007, 11:51 AM
