OVERHEATING!!!!!!!!!!! - Printable Version
+---- Forum: Heating, & Cooling Systems (
https://968forums.com/forum/heating-cooling-systems)
+---- Thread: OVERHEATING!!!!!!!!!!! (
/overheating--12880.html)
Aro51 - 05-21-2007
I woke up Sunday morning at 6:00 and headed out to the autocross in Miami. I was on the Florida turnpike until 30 mins later I see my temperature rising slowing and the emergency light faded on slowly. I pulled over and I took a look under the hood and nothing was leaking. I hopped back in and kept going, keeping an eye on the temperature. I noticed the temperature would bounce around when im going past 60. I headed home in dissapointment. The water pump was already replaced before this incident. It might be the radiator? any suggestions?
Thank you,
Alex
flash - 05-21-2007
do not drive it any farther - you really need to get that sorted out before something very bad happens
it could be a failed pump - it happens with new ones too
could be a stuck tensioner - causes the pump to not be driven
the likely suspect though is that it could be a stuck thermostat
PorscheDude - 05-21-2007
Did you bleed the cooling system?
94SilverCab - 05-21-2007
Are hoses getting hot top and bottom?
Fans kicking on?
I'm betting water pump...
just my $.02 (Got change for a Hundred?)
Eric_K - 05-22-2007
I'll second the vote for stuck thermostat.
sp4149 - 05-22-2007
Check Fluid levels when cool. I didn't have leaks but had overheating episodes.
I started to notice that coolant level in the reservoir kept going down, but no leaks
and no coolant on the ground. Eventually I got white smoke upon start-up,
after a new head gasket no problems. Losing coolant without obvious leaks
is a bad symptom.
-sp4149
