Well the good news is I discovered why they were not working. They were not plugged in.
The bad news:
I knew that the drivers front corner suffered a minor collision that was corrected with 6k worth of factory parts, but they left out the clip that holds the small black bumper in as well as the screw that hold the lamp in. When I took the small black bumper screws out and pulled it away from the body I heard nuts falling. I knew this was bad and then saw the missing screw for holding the lamp assembly in. I do not see any way to hold the screws in place to put the assembly back together so I guess I’ll try some large sheet metal screw to temporarily hold it in there. Any ideas on finding the clip? Can I put it in without removing the bumper? I was just looking at the picture. I wonder if I can get to the screws with the side marker out?
