Need advice on choice of new cam
I had my mechanic pull the valve cover to take a look inside and he said there are 2 BAD lifters. He's not sure about the cam yet but said I may need one. (two, I suppose)
I've done preliminary investigation on places that sell cams; RS Barn, Webcam, Pelican, Sunset. Prices seem to vary widely (if I read correctly) from about $600-1,600? I think they are all for the set of 2. Can anyone confirm this?Also, there are new, reground, and performance cams.
If I am shelling out such large sums anyway, I think I would prefer a performance cam. I'd like to feel SOMETHING for my money, after all. Are there any negatives to this? What are gains in power on an otherwise stock car?
Do I need to replace all lifters or am I OK with only replacing the 2 bad ones?
I assume I need to change the chain and tensioner pad. Is there anything else?
I am talking to the mechanic again tomorrow afternoon so I'd really appreciate feedback so I can decide what approach to take.
Thanks!
Todd
Todd951968
Scuderia Corrente:
944 Turbo
968: GP white/lite grey sport seats, M030 sways, Cup1's
911 SC
BMW E30 325IS
Jeep Commander (Porsche puller)
Cavalli Pascolati:
<b>VW's </b> : '92 Corrado VR6-stock, '87 Scirocco 16v-modified, 1984 GTI, 1981 VW Cabriolet
<b>MB's</b>: 1970 MB 280SEL
<b>American</b>: 1993 Pontiac Formula, 1991 Talon TSI, 1978 Z28, 1975 Trans Am
be very careful about performance cams - there are a couple of companies out there that are selling cams that flat don't work - so far, the only performance cams i've heard of that actually work are from rs barn - not sure if they will work on an otherwise stock engine though
i'd call pete and pick his brain
Performance Cams on a stock engine should give you an increase in power based on past experiance. However, you will need a dyno tune to optimize the gains as there is no chip for just cams. I wouldnt install Cams unless you are doing other work. The gains will be very minimal based on the fact that you would be running a stock header/exhaust/intake.
And if you do cams & a dyno tune, once you install other mods, you will need to do a re-tune to optimize everything again.
But who knows, they may do more then i think. I don't think anyone in the 968 community has done just cams alone.
I did the airbox mod but didn't think exhaust and headers were good for any gains. In fact, I thought the stock exhaust was as good as you could get, for power.
Todd951968
Scuderia Corrente:
944 Turbo
911 SC
BMW E30 325IS
Cavalli Pascolati:
The original exhaust is a nice design, but has been found to be restrictive at high rpm. If you'd like to get the specifics, I'd suggest contacting RSB. I have an RSB cat-back system and wish I had installed it earlier.
nope - no gains from just a cat-back, and in fact all but the rs barn system loses one place or another, but there are gains from the header - do a search here - you will find dyno charts to illustrate that
After removal of the resonator I'd be really surprized if there weren't some gain at the top end...
i drove a car like that - there was a bit of extra snap over 5k (probably 3-4hp), but a dip in torque at just over 3k, just like every "free flow" system we've seen so far - gas velocity is critical on this car
Last Post by Ryan
06-26-2019, 03:00 PM
01-01-2015, 12:55 PM
Last Post by MLB
05-29-2014, 06:17 PM
Last Post by MB968
03-13-2014, 02:19 AM
05-17-2013, 12:56 PM
